Hey guys
I built my PC around 7 months ago, everything has be superb since, except last week. Whilst playing GTA4, my screen locked-up and showed thousand of multicoloured pixels, to which I then had to restart.
The next day, it happened again playing CS, except this time the lock-up showed a full green block colour. This happened around 4 - 5 times the next day, until finally I reseated my RAM, Card, wires etc. It then worked for around 6 hours, but then happened again. The weird thing is, my temps never go above 70 degrees full load as i manually set my fan to +65% anyway, so heat is not an issue. I get around 38 - 45 degrees idle.
At first i thought maybe a driver was the problem, since my card was basically brand new, and been used for only 6 months. However since then, when I boot up my PC, the graphics card fans act erratic starting at 100% and then going to 40% then back up to 100% and then finally after a suitable amount of time 30 - 1 minute, it will boot and load up vista.
If anyone has had a similiar problem, or thinks this is definitely a card malfunction please give me some advice, as i'm not sure what to do. I'm not even sure OCuk do RMA 6 months later?
Thanks for any help in advance.
