I'd recommend reading through this thread from EVGA forums.
"The hotspot issue is a misconception based on a review where the reviewer in question was running Furmark, an extreme usage case, as most overclockers know. We believe this is a good approach to have some idea about the graphics card limit, and the thermal performance under the worst case scenario. EVGA has performed a similar qualification test during the design process, at a higher ambient temperature (30C in chamber) with a thermal coupler probe directly contacting the key components and after the Toms Hardware (Germany) review, we have retested this again. The results in both tests show the temperature of PWM and memory is within the spec tolerance under the same stress test, and is working as originally designed with no issues.
As for your card, it is not affected, as the "issue" has only been found to affect the FTW models, which are a non-reference PCB. Your card, the SC, and other reference PCB models do not exhibit this "hotspot". However, if you wish to obtain the thermal pads for your card, you may do so, as long as your product is ACX 3.0 and has a backplate. To request these, please go to ..."
http://forums.evga.com/Is-the-EVGA-1070-SC-effected-by-the-VRM-overheating-issue-m2571376.aspx
Not checked in to see how this issue is playing out for a few days. I get what evega is saying. Would be nice to see some more information though. I have a classified rather than an ftw.
Last evega thread I read all I got from it was that the Evega mod. did not like the term problem as it indicated an issue.
Today I learn it also does not like the word affected.
Question: "Is the 1080 classified affected by this"
Answer: "Fortunately none of the cards are effected by an overheating/VRM issue."
I think I would have run with none of our card are effected by this but we are offering thermal pads for the 1080 classified so our custmers can enjoy lower temps.
Not learning anything other than Evega appear to be using The Parniod Troubleshooters Guide To The English Language. Which only seems to give a single worse case reading for each word.
Does not look like customer support it reads like damage limitation.
