- 14 Dec 2010
Hi all,
I've built a beast of a machine here at work for a developer with a dual processed EVGA SR-2 with 2 x overclocked Xeons along with EVGA SLI GTX580 Classified Ultra's in SLI, and whilst I'm able to check the overclock of the CPU's (running at 4.2Ghz), I'm also wanting to stress test the SLI setup of the cards as well to check case temperatures when the whole thing's under load.
I've tried Furmark, but unfortunately it only seems to load up 1 GPU, and I think it uses a bunch of CPU as well. Can anyone recommend something that will either a) load up the entire system (CPU's and GPU's all at once), or b) Just load up both video cards so I can continue to run Prime95/Intel Burn Test on the CPU's whilst it hits the graphics cards.
As usual, many thanks in advance.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
![IMG_0490.jpg](http://i28.photobucket.com/albums/c203/Dalai_Lager/IMG_0490.jpg)
