** EVGA SUPERNOVA PSU DEALS WITH A 10YR WARRANTY!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As always EVGA like to go one better than everyone else with their warranty and service, 10yr warranty, NUFF SAID!
Three deals for you guys:-
EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply @ £139.99 inc VAT
The EVGA SuperNOVA 1000 G2 has arrived! This power supply is 80 Plus Gold Rated, offers 1000W of continuous power, exceptional efficiency and is fully modular. Not to mention, a first class 10 Year EVGA Warranty. Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G2 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G2!
NOTE: For power supplies purchased in Europe, a European style power cable will be provided.
Features:-
- Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
- 80 PLUS Gold certified, with up to 90% efficiency under typical loads
- Highest quality Japanese brand capacitors ensure long-term reliability
- Fully Modular to reduce clutter and improve airflow
- NVIDIA SLI Certified
- Sanyo Denki Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
Was [£149.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply @ £109.99 inc VAT
Unleash the next generation in power with the EVGA SuperNOVA 850 G2 Power Supply. Based on the award winning G2 series Power Supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The new ECO Thermal Control Fan System offers fan modes to provide zero fan noise during low load operations. Backed by a 10 year warranty and Japanese capacitor design, the EVGA SuperNOVA 850 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
Features:-
- NVIDIA SLI Ready
- Double Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP - (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
Specification:-
- ATX Cable 1x 600mm (m)
- EPS Cable 2x 700mm (m)
- PCIE Cable 2x 700mm, 850mm (m) 2x 700mm (m)
- SATA Cable 2x 550mm, 650mm, 750mm (m) 1x 550mm, 650mm, 750mm, 850mm (m)
- Four-Pin Peripheral Cable 1x 550mm, 650mm, 750mm, 850mm (m)
- Floppy Adapter 1x 100mm
- AC Power 1x 1500mm (m)
- CONNECTOR QUANTITY
- 24 Pin ATX 1x
- EPS (CPU) 2x 8pin (4+4)
- PCIE 4x 8pin (6+2), 2x 6pin
- SATA 10x
- Four-Pin Peripheral 4x
- Floppy 1x
- 12v: 70.8A
- Size: 85mm (H) x 150mm (W) x 180mm (L)
- Approvals: TUV, CB, CE, FCC, RCM, cTUVus, BSMI, WEEE, RoHS
- Warranty: 10yr
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply @ £89.99 inc VAT
Unleash the next generation in power with the EVGA SuperNOVA 750 G2 Power Supply. Based on the award winning G2 series Power Supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The new ECO Thermal Control Fan System offers fan modes to provide zero fan noise during low load operations. Backed by a 10 year warranty and Japanese capacitor design, the EVGA SuperNOVA 750 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
Features:-
- NVIDIA SLI Ready
Specification:-
- PCIE Cable 4x 700mm (m)
- SATA Cable 3x 550mm, 650mm, 750mm (m)
- Four-Pin Peripheral Cable 1x 550mm, 650mm, 750mm (m)
- 24 Pin ATX 1x
- SATA 9x
- Floppy 1x
- INPUT
- Input Voltage 100 - 240 VAC
- AC Input 10A
- Input Frequency Range 50 - 60 Hz
- Efficiency Gold Rated - 90% Typical
- 12v - 62.4A
- Dimensions: 85mm (H) x 150mm (W) x 180mm (L)
- Approvals TUV, CB, CE, FCC, RCM, cTUVus, BSMI, WEEE, RoHS
- 10yr Warranty
Was [£99.95] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Less than £90 for a fully modular gold standard PSU with a 10 year warranty is a bargain. Might have to finally replace my 8 year old Corsair TX750.
As these are based on the G2 platform and have a 10 year warranty, i presume the OEM for the 750w and 850w units is Superflower just like the 1000w and 1300w units. The 750w and 850w units are so new they are not even up on the PSU database yet.
Super prices for the warranty, I'd be happy to pay £140 alone for 10 years worth of warranty on an electrical product but to get the item itself for that with the warranty is brilliant, especially with EVGA.
Only thing to bear in mind is that the PCI-e cables are red on the EVGA units which is what swayed me towards the Superflower versions instead as they have all black cables.
So practically the same costs as if RMA is sent to a Corsair product then? ^
I also was told from an EVGA rep that their warranty is based on the serial number of the PSU and not the customer.. so you can resell it, dont have to keep invoices (even though all you do is check email) and keep value to maximum..
Just hate how weird the psus look lol but you never see them inside the case anyway...
What a ridiculously low price these 750/850w G2's are! Pretty comparable performance/build quality to Seasonic X/Corsair AX and AXi yet they're priced against mid-tier stuff like Corsair RM (which it absolutely destroys)
I was lucky to grab the 1000w P2 supernova, when it was on offer few weeks back.
Thats same generation, just a bit higher efficiency.
It works fantastic.
Trojan, you are right about warranty. You can register the psu to yourself and if you decide to sell it, you can un-register. It will be removed from your evga account and the new owner will be able to register it again.
