EVGA x79 FTW - RAM issue
16 May 2010
Dorset, UK
Evening guys,
Just finished putting together my x79 build.
Populated all the RAM slots on my EVGA x79 FTW board with 16gb of Corsair Vengeance 2133MHz 16GB and it didn't boot. Wouldn't even post.
Remove the stick of RAM from the slot furthest from the CPU on the right hand side of the board and the PC boots.
Tried booting from every slot on the board with a single stick and it works bar the slot outlined above.
Even tried with a set of Corsair Dominator dimms with no luck.
Put a single stick in another slot and check it boots. I then put a stick in the potentially faulty slot and the machine doesn't boot.
Any ideas guys?
Pretty gutted as it has taken a while to get this lot together.
CPU is a 3930k if that helps.
Cheers
Sounds like a dead stick of ram do memtest I had this with a new set of ram I got from the shop.
Have you over tightened the heatsink thus slightly bending the board which could cause connection problems for the ram slot or again the CPU?
It's on water with a EK Supreme HF block. Doesn't do up massively tight so I wouldn't think so! Thanks for the reply.
Be sure to try updating the bios, its well known that EVGA have struggled with X79 in the bios dept.
This was the next port of call. It isn't running the latest BIOS so hopefully this helps!
I've tried with 2 different sets of RAM. One set I know is a 100% working as I've been using it for the past 3 years in my x58 build.
Whats the post code nick? also don't put the 47 bios on its a pile of crap stick with the 45.
Is that the code that appears on the little LCD screen on the bottom left of the board?
Will let you know. Bear with me.
Also, I will leave the BIOS update for now!
That's cpu or ram problem have you takin the cpu out to check for bent pins,you done a memtest yet?
I checked for bent pins before installing the CPU, everything looked absolutely fine!
The Dominator memory I have tried is all good.
Memtested for over 10 hours without an error, on top of that, I have been using it for the last 3 years in my x58 build without a single problem. Still the machine won't boot when the suspect slot is populated.
Very strange!
Take of the cpu waterblock and the cpu you may have bent one of the pins when you put it on,also is the cpu new or secondhand.
I will remove the waterblock when I get home.
Socket looked fine beforehand so I wouldn't imagine anything was bent during the fitting of the CPU, I will be taking a look though.
CPU was from the MM.
Cheers for the help so far!
Like stulid said sometimes the waterblock mountings can be to tight and need slacked off a bit,did you have to put a backplate on the cpu block ? also you checked theres nothing in the case shorting on the back of the board.
Im glad to help out nick if your still stuck send it to me and I can test it as ive still got my old 3820 cpu.
Forgot to say there are switches to Disable all the DIMMs on the board maybe you have knocked it to off for that slot?
That's cool, will give it a go later on!
It didn't need a back plate, the mountings screwed straight into the 2011 socket.
I've checked for a short and cannot see anything.
Will remove the board, check for anything that looks out of place, reseat and retry.
Thanks Joe, hope it doesn't come to that but nice to know the option is there :)
Just trying to help out mate :) you do know there are 3 bios on the board maybe try number 2 don't forget the DIMMs switches.
Yep! I've tried all of them. Goes to boot into Windows but hangs. I thought AHCI settings to begin with but all of them are AHCI enabled so I gave up.
Checked the DIMM switches and all of them are in the ON position.
Strangely though, with the suspect slot populated, and the switch for that slot in the OFF position. It still doesn't post!
