. so you haven't told me, whats going in the rack? Are you going to put your DroboPro in there, you can mount these in racks which would be awesome if connected to a server to go with a switch/hub for all those darn CAT6 cables![]()
Good thread, kudos for doing it and especially taking photos all the way through. I Just bought a 1930s semi which Im doing some work on, so its good to see ideas.
There are some things I do find strange, especially the multiple three pin sockets in the comms cab? I would rather fit a surge protection strip, then you have an easy option of fitting a beefy UPS in the future if needed.
Also I dont think I would have run Cat6 (and do you really need so many?), to my mind cat5e would suit most situations?
I will be running some cat5e soon around my place and im genuinely interested in what you intend to use all your cat6 cables for.
snip
Fair comments, what are the cost implications of the usb over cat6 baluns? would they function the same over cat5e? I dont know a lot about them, do they support full speed? usb3.0? attenuation limit? other protocols supported (i know of HDMI but know its fairly expensive)
I havent looked at pricing but did you go for cat6 or cat6a?
I like the idea of sending hdtv to every room from one source, have you thought about things like IR lag and multi-room usage? - could be an interesting system.
If you are whacking all that in to the rack I'm guessing you have some sound proofing solution for the massive amount of "hum" you will get?
. I do still have acoustic insulation if worst comes to worst.snip
Thanks for the response
Hmm for me it would have to be usb 2.0 but also for me £300pu is prohibitive, 50m is reasonable and im thinking should suit most homes.
That sure is an expensive piece of kit (hdmi switch), does it do anything cleverer than just split the signal? im guessing it does, please divulge
With the 720p/1080p issue surely the 720p kit will just dither to 1080i?
Im intrigued to know what this matrix switch is capable of.
If I ever see Kevin McLoud snooping around here I'll chin him!Only really decided to read this thread recently. Never really noticed it before.
Absolutely amazing stuff, I would love to do something like this with enough time and money one day. I'd have to muster up the inhuman amount of effort required first too
Well done to EVH, epic job and looks like it is doing really nicely!
It's like OcUK's own grand designs![]()
Out of interest, where'd you get your matrix? I need 6 inputs, 8 if I want expansion, but I haven't found many places that sell them outside of the usual couple of etailers and even then they are imported from the US which I don't fancy.EVH, if you could get away with a 4X4 matrix these work out much cheaper, I picked one up that outputs over cat5e/cat6 including baluns for £300.
2001: A Space Odyssey.. anyone? It'll take over the house!!
heh, Build looks awesome. Wife and I are seriously considering doing a timber-frame house. I'm looking for the catch!
