- 5 Jul 2005
Hi.
So I got my first SSD on Sunday and installed Windows 7 Pro on it. My system is Asus m5a97 r2.0, Phenom ii X4, 4 gig RAM, 6670.
I did a fresh install of Windows 7 64 bit and made sure that the SATA port was set to AHCI.
I must say that some of the optimization guides on the net for Windows 7 and SSD's are rather dated. I was reading one that told me to disable cache, which I did and my write speeds fell off a cliff. I thought my drive had buggered up. I quickly enabled it.
What I have done is:
Verified trim
Disabled Hibernation.
Disabled System Restore
Disabled Drive Indexing
Disabled Drive Defragmentation Schedule
Disabled Prefetch and Superfetch in Regedit (I originally did this in Magician but looking in regedit they seemed to be still on)
Disabled Windows Search and Superfetch
Disabled ClearPageFileAtShutdown and LargeSystemCache (These were already disable so maybe Win7 did this automatically)
Set power setting to HIGH and adjusted SSD sleep to NEVER
Pagefile has been left unaltered.
Does the above info look ok or have I gone too far with certain things? I originally just used Magician but decided to uninstall it and do everything manual from net guides, but like I was saying some guides have dated or wrong info.
Here are my results:
Uploaded with ImageShack.us
What do you think? Should I be worried about the low IOPS for read? Is it worth updating my BIOS because I think its a couple of versions old.
Cheers.
Verified trim
Cheers.
