- 23 Jun 2004
- Blackburn
Is there anyway to avoid taking the loop apart all apart and cleaning it? Like if you replaced the liquid every 6 months say? I really want to do this for my next build wether that’s doing it myself or a pre build or getting someone to do it. Just taking it apart scares me
Never used them myself but Mayhems sell Blitz System Cleaning kits for cleaning water loops. Again never used it myself but I think your supposed to drain your loop, add the cleaning agents from the kit to your loop. Run it for a while and then flush it out and refill with coolant.
Reason I've never used a Blitz kit is one cost and two I prefer to dismantle my blocks and clean by hand, that way I can see if its cleaned thoroughly and check for blockages etc.
but im planning on spending plenty of time figuring our what i need to do it right, but yeah its fairly daunting but theres so much expertise out there to get advice from, it doesnt have to be a lonely solo journey.
