- 3 Jul 2004
I thought I would post an example of really bad case design:
This is my existing case, that I bought a couple of years ago from a competitor. The picture shows where you screw expansion slots to the case - note the metal flange above the screws (running vertically to the left of the screws). This flange means I have to flex and bend the card to force it pass the flange so I can screw the card in. You would be amazed at how much give there is! I sometimes think the card is about snap in two before I can force it home. You can see the scratches in the metal as a testament to my perseverance.
What genius designed this? They obviously did not use it for real before letting it out of the factory door.
My PC needs a spring clean, so I have decided to take it apart completely, clean all the components and then put it back together. I can't face battling with my existing case, so I am going to buy a new one. Any recommendations? Here are some requirements:
ATX Tower, preferably biege/white (not black)
No see through or glowing bits.
Ease of use! e.g., screwless internal drive bays, panels etc.
Up to about £70.
Anyone else have horror stories they would like to share?
Up to about £70.
