- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi have the following spreadsheet, this is a data LUA extract I have made using the following code
But I wanna convert the spreadsheet to total all mobs the same name but different lvls into a single kill total? Any ideas how this could be done using a formula or something in excel.
Thanks
Code:
floor = math.floor;
function GetDifficultyColor() return {r = 1.0, g = 1.0, b = 1.0} end
loadfile("MobInfo2.lua")();
loadfile("MobInfo2/MobInfo2.lua")();
loadfile("MobInfo2/MI2_Health.lua")();
loadfile("MobInfo2/MI2_ConvDropRate.lua")();
columns = { "name", "level", "healthMax", "kills", "loots" };
io.output("data.csv");
for i, v in ipairs(columns) do io.write(v .. ";"); end
io.write("\n");
for key,v in pairs(MobInfoDB) do
local name, level = string.match(key, "^(.-):(.-)$");
local data;
local kills = 0;
for _, user in pairs(MI2_CharTable) do
MI2_PlayerName = user;
data = MI2_GetMobData(name, level);
if data then
if type(data.kills) == "number" then kills = kills + data.kills; end
data.kills = kills;
end
end
if data then
io.write(name .. ";" .. level .. ";");
data.loots = data.loots or 0;
for i = 3, #columns do io.write(tostring(data[columns[i]]) .. ";"); end
io.write("\n");
end
end
Thanks
