Excel - Can it be done without VBA?
20 Feb 2004
La Romana, Spain
I'm trying to create an example tool in Excel and can't work out how to get it to do what i want and i think VBA may be required but i'm not great with it.
Heres a screenshot of the base file.
I have a monthly period. With a set of parameters on the left
Review Period
Lead Time
I have done a formula, not very clever but it works and my brain isn't functioning to do it better. Which says if the review period is every x months then stick an "R" into the review row.
I then say that
-Opening stock - is based on a predetermined figure to start and then equals the previous months closing stock.
-Issues in Month - is entered as forecasted
-Receipt in Month <---What my issue is with
-Closing Stock - is the sum of the above
-Order Placed - this says if the top row = "R" then calculate "Max Value" less "Closing Stock"
What i am trying to do is factor in the lead time for the "Receipt in Month" row. To say if i say an order is placed, then in x number of months enter the order into the receipt field. I know in VBA you can move the cursor around a specific number of cells and paste data but that doesn't feel like the right solution.
As mentioned i'm tired and not slept a lot so i'm happy to accept i've not set this form up very well.
I suppose using my parameters of 3 monthly review and 1 month lead time i'd expect it to look as follows
File here
http://www.filedropper.com/13examplemin-max20170313-mt
Any help would be much appreciated.
EDIT - I'm now wondering if i can use Index/Match to get it to do this but using the Lead Time to specify the row i want to pull data from.....or i'm clutching at straws and should just go to bed!
Well i've got something working. Have used the Offset function, which i guess is what i was getting at with VBA
=IFERROR(OFFSET(I7,4,-$B$3)*1,0)
Then looked 4 rows down and then used the column reference to be -"whatever is in Lead Time"
Because it then pulled in "Review to Order" depending on the entry i had to multiply by 1 and use an iferror.
An absolutely shocking workaround which i'm sure you'll cringe at but it'll do for the time being!
c# was never going to replace VBA?
Office programming in visual studio is a separate thing entirely. MS have never been in any hurry to dump VBA which is supported in every version of office.
