Excel formula help
18 Oct 2002
Southend-on-Sea
Can anyone help with an Excel formula please? I have a sheet of client data (names, addresses, email, etc). It has a date of birth column and I want to create a new sheet that will display only people with birthdays in the next 30 days.
I don't have much Excel knowledge and I seem to be going round in circles with the help system. Would this be the correct process:
1. Add an extra column to the existing sheet that would contain a flag if the birthday is in the next 30 days.
2. Use an advanced filter to add those records to another sheet.
Is that right?
For step 1, I can set a flag if the dob matches today's date using:
Code:
=IF(MONTH(K10)<>MONTH(TODAY())," ",IF(DAY(K10)<>DAY(TODAY())," ","Flag"))
But how do I expand this so it flags if it matches any date in the next 30 days?
Thanks
But won't that only show records that match the date in 30 days time? I need anything within the next 30 days.
Something like this will work (not in Excel so you might need to correct my syntax a bit).
=IF(AND(K10=>TODAY(),K10=<(TODAY()+30)),"TRUE",FALSE)
OK, almost got this working now. I created a new column that shows their next birthday then used the following code to identify upcoming birthdays:
=IF(AND(N18>=TODAY(),N18<=TODAY()+30),"BIRTHDAY"," ") (thanks Makhaira)
Can anyone help with the next step. I need to create a link for each record that when clicked on will automatically open a mail in Outlook and populate with their email address, a subject line, and then their name and birthday within some predefined body text.
I've googled but it all seems very technical. Does anyone know of a decent guide/tutorial for doing this?
Thanks
I think that you will need to use VBA or VB.net to perform this task.
sample
Sub mailto_Selection()
'David McRitchie, 2005-08-01 modified for selection,
' http://www.mvps.org/dmcritchie/excel/email.htm
Dim Email As String, Subj As String, cell As Range
Dim response As Variant
Dim msg As String, url As String
Email = "" 'create list below
Subj = "Family Newsletter"
msg = "Dear Family,"
'-- Create the URL
For Each cell In Selection
Email = Email & cell.Text & "; "
Next cell
url = "mailto:" & Email & "?subject=" & Subj & "&body=" _
& Replace(msg, Chr(10), "/" & vbCrLf & "\")
MsgBox url
url = Left(url, 2025) 'was successful with 2025 , not with 2045
'-- Execute the URL (start the email client)
ShellExecute 0&, vbNullString, url, vbNullString, vbNullString, vbNormalFocus
End Sub
You will need to define range, which will be your liting from above
andy.
Yes, seems VBA is the way to go. Found some code that looks like it will do the trick. Just need to customise for my needs.
Thanks.
