Excel heed scratcher
6 Jan 2013
Rollergirl
I have an Excel sheet with multiple tabs. One of the tabs won't scroll up and down with my mouse scroll wheel, I have to drag the scroll bar. All the other tabs are fine.
Help me, please.
Weird. Does it have lots of macros running? Lots of hidden rows or columns?
What happens if you delete everything on the sheet - is it still un-wheell-scrollable?
What about if you copy everything onto a brand new fresh sheet - can you scroll in the new sheet?
It's not a freeze frame issue, which I proved by adding a freeze frame and then removing.
I deleted all the rows and it still wouldn't scroll.
It's making me a bit :(
Delete that post right now!
This should just be marked as "resolved" and thread closed.
Thanks for the solution, will store that knowledge away for the day 4 years from now when I'm trying to browse some humungous database someone's built in excel and not being able to wheel scroll will drive me uo the wall :p
If I'd said it was a column on the left that I wanted on the right of the sheet, the thread would be a 20 pager by now.
The art of the Geek is dead here. Dead I tells ye.
*Hings heed in dispair*
