Excel help (please!)
5 Mar 2007
Macclesfield
Hello,
I need some Excel help! I have a spreadsheet with 4 lines of an address in columns
House # Street Town Etc.
I'd like to merge these into one cell, and one below the other (standard address):
House #
Street
Town
Etc.
I’m sure there is an easy way to do this but I can’t find it.
Can anyone help?
Cheers
=A1 & CHAR(10) & A2 & CHAR(10) & A3 & CHAR(10) & A4
Replace A1 etc. with your cells.
Note: The target must have text wrapping enabled or you will get a symbol instead of the newline.
Thanks, i need to change it a little bit as i wanted to pick cells accrss not down, but i couldn't have done it without you!
=D4 & CHAR(10) & E4 & CHAR(10) & F4 & CHAR(10) & H4 & CHAR(10) & I4 & CHAR(10) & J4
Cheers
EDIT
Just read the note part again and appreciate that I’ve pointed out exactly what you said...must stop drinking on Thursdays!
