- 23 Dec 2002
- Under my desk
Hi Guys,
having a problem with excel and I'm hoping that you all can help!
An excel spreadsheet is created from the logs of some telnet sessions, this puts a capital 'C' at the top of the worksheet.
When you try to open the worksheet Excel says 'Cannot Open Protected File' and won't let you do anything. However, if you open the spreadsheet in notepad and remove the 'C' excel will then open the file.
I need to know if there is a fix or workaround to allow the spreadsheet to be opened with the 'C' in place as it's not practical from me to remove the 'C' everything the file is created (due to it being created in a series of macros)
Any help would be really good as it's sending me up the wall!
Cheers
Kev
/Edit:
Tis Excel 2003 and patched with the latest office service pack.
Cheers
Kev
/Edit:
