Hi,
I need to create a CSV file to bulk import about a hundred or so users into AD. I have been given an excel worksheet with the names in this format in one column:
I need to separate the first name and surname to form the username (Via the concatenate function) Basically, I would like to know if there is any excel function (Or work around methods if there aren't any) to separate the names at the comma or space and put them into two separate columns like so:
Thanks for any advice
Ben
Code:
A
Bloggs, Joe
Code:
A B
Bloggs Joe
Ben
