Excel Lookup Help
28 Dec 2003
Aberwristwatch
I'm trying to compare the contents of two folders by importing the filenames into Excel. I have one spreadsheet which has 'E-ISBN' and 'Book Name'
In another spreadsheet I have imported the filenames of the contents of two folders. One containing the E-Books named using the E-ISBN and another folder of covers, again anmed using the E-ISBN
However these two folders do not match. Some E-books are missing from the E-Books folder. What I need is for the 'Book Name' from the first spreadsheet to be inserted in the third column of the second spreadsheet in the correct row.
Spreadsheet One
E-ISBN Book Name
100 Book1
101 Book2
102 Book3
Spreadsheet Two
E-ISBN Cover Book Name
100 100 (From Spreadsheet One)
101 101 (From Spreadsheet One)
102 102 (From Spreadsheet One)
(There should be tabs separating the above)
Vlookup is what you need.
Sort the spreadsheets by E-ISBN
then in the third column use
=VLOOKUP(A2,Sheet1!A:B,2,FALSE)
assuming the E-ISBN is in column A and the lookup sheet of the E-ISBN and book names is on Sheet1 in column A and B
