Excel query problem
23 Apr 2007
Cardiff-ish, Wales
Hi guys,
I've got two spreadsheets: Provider Master and Provider Template. The Master contains all the data of multiple providers, the Template queries the Master and pulls in the data for a single provider through a drop down list.
Problem - most of the data is pulled across but the last 3 columns won't pull in the text. However, if I change the original text to numbers then it works. I can't see any differences in the formatting etc. All the blank cells in the returned query show a 0. However, in the cells where data should be pulled across (not every cell has a value in the master list) show as blank.
Any ideas?
Are the cells on the destination template set to specific data types (I.e set as text as that's what you wanting to bring across from the master)
Just checked and the formatting is the same. I've even copy paste special format from a column that works to make sure ... still pulling in blanks. Very odd.
Without seeing the formula I can only guess but is sounds to me that the lookup is failing as you are mixing text and number values. Try adding -- before the value in the lookup this will convert the cell value to a number.
F2 enter on a couple of the cells that aren't pulling through and see if it changes anything. If so, it's time to get busy with Ctrl-H (find and replace).
I have this problem (if that's what it is) on many of my spreadsheets. Numbers formatted as text don't get found by VLOOKUPS until I F2, Enter on each blummin cell if there aren't too many, or Find and Replace from 0-9.
Sorry for the delay, I hadn't check the post for a while.
F2 doesn't do anything.
There are no numbers in the cells it's pulling over - it's either an R,A or G as a code for Red, Amber or Green. The other info it pulls over is a description of the status ie why it's a Red, Amber or Green.
There's no formula to post as it's a query? Or do you want to see the query formula?
Connection String:
DSN=Excel Files;DBQ=Z:\Test 20110519\Provider Dashboard Master.xlsm;DefaultDir=Z:\Test 20110519;DriverId=1046;MaxBufferSize=2048;PageTimeout=5;
Command Text:
SELECT DataInputAll.Provider, DataInputAll.Cat, DataInputAll.ProviderCat, DataInputAll.`2010 Q1`, DataInputAll.`2010 Q2`, DataInputAll.`2010 Q3`, DataInputAll.`2010 Q4`, DataInputAll.`2011 Q1`, DataInputAll.`2011 Q2`, DataInputAll.`2011 Q3`, DataInputAll.`2011 Q4`
FROM DataInputAll DataInputAll
WHERE (DataInputAll.Provider=?)
It works fine up to DataInputAll.`2011 Q1 and then it just shows a blank rather than the value.
