Excel VBA help
25 Aug 2005
Derbyshire
I am trying to restrict printing on an excel sheet I have. I have managed to do this by using VAB and the following code
Code:
Private Sub Workbook_BeforePrint(Cancel As Boolean)
Cancel = True
MsgBox ("If you require a hard copy of this sheet, please inform xxxxxxxx")
End Sub
Now, I want to be able to allow users to print if they enter the right value into a textbox in a userform and then press a "print" button. This is what I'm having problems with.
It will obviously have to involve an if statement along the line of:
Code:
If textbox1 = "value" then
activeworksheet.print
Else cancel print
But I'm having problems with the correct VBA terminology for this.
Any help would be great, thanks
Never mind. I found a way. Just for anyone that is interested, I did it this way;
Code:
'must lock VBA project so you can't see the password in it
'Input box to verify password before printing
'put in this workbook module
Dim myPassword As String
myPassword = InputBox(prompt:="Due to the sensitive nature of the material printing is restricted. Please obtain a password from xxxxxxx to proceed:", _
Title:="Password is required to print this file.")
'change password to what you want
If myPassword <> "xxxx" Then
MsgBox prompt:="Click OK to return to Report.", _
Title:="Cancelled -- correct password not entered", _
Buttons:=16
Cancel = True
Else
End If
End Sub
