Exchange 2010 issues! (with Ex2007)
28 Sep 2008
Britain
Hi Guys, doing an upgrade.
Got two servers running now, both have the same roles enabled:
One 2K7 and one 2010 server.
I've started to move mailboxes to the new server but those users who remain on Ex2K7 can send but not receive email (external or internal).
Whats up here?
Also, for the life of me, Public Folders don't seem to replicate. I've looked at almost every google result and can't get it to work.
So, whats up with that!!
EDIT: Solved the first one, the receive connector in the Ex2K7 box had been disabled :)
Now its just PFs
Resolved both now, thanks.
One thing that is annoying me. I can't get my Nokia E72 to sync with my Mailbox. If I choose any other user from the org, it works, but not mine.
This seemed to randomly stop working from yesterday, it did work before (exchange 2010). What settings are there which allow syncing of mobile devices?
Ta
Ah crap, yeah.
I know there is Hub..errr.. Transport (? :D) > Client Access but that's just generic settings right? I cannot actually recall seeing the old AD User based feature settings in Exchange 07+
Do tell when you find it :D
Are you a domain admin?
Domain admins have OMA disabled as a "security measure" in exchange 2010.
There is a workaround however I forget it off the top of my head. I had to "sort" mine out to get my iPhone to sync.
I am a domian admin yeah. Thing is, it did work, now it doesn't.
Viewing the IIS logs, I see this:
/Microsoft-Server-ActiveSync/default.eas User=me&DeviceId=IME(myIMEI)&DeviceType=NokiaEmail&Cmd=FolderSync&Log=V121_LdapC26_LdapL96_RpcC18_RpcL15_Ers1_Pk0_S111_Error:InvalidPolicyKey_Ssu:2007_Budget:(A)etc, etc domain\user 212.183.140.1 NokiaE721/2.01(0)MailforExchange 500 0 0 6625
I've replaced my username and IMEI in that above message. I'm particularly interested in the Error:InvalidPolicyKey error and the generic error at the end, both of which I've googled to no avail.
If you can remember what you had to do, I'll give it a shot.
IIRC you have to temporarily remove yourself from Domain Admins, then open ADUC (as another admin), and change your user object's security permissions to be "inherited from it's parent".
Then reconfigure the device, make sure all is working ok, and re-add yourself to the domain admins group.
All working now. So odd how it was working fine before, but thanks anyway. You should blog that as loads of people are having issues
I prefer to keep my services "chargable", I'm just that good :p
By "working fine before", I assume you meant when your mailbox and OMA were hosted on the 2007 box?
I think you may be right. I thought they had moved across to the 2010 box and it was still working. Obviously not.
Thanks again
Now I just need to Public Folders to work in OWA (they are fine in Outlook), and I can kick the 2007 box in to touch and upgrade it :)
