Exchange, SSL and IMAP
6 Jun 2005
Cambridge
Hi All,
Recently a colleague of mine implemented a Microsoft Exchange 2003 mail server at a company and bought a SSL certificate from a valid CA (Comodo).
We can use webmail without any issues, and the SSL certificate is valid through all our browsers.
Some phones however, are having issues.
We have a range of Nokia/apple/Samsung etc phones.
All the iPhones work without issues.
Some Nokia phones will work fine without issues
Some Nokia phones will complain the SSL certificate is not valid
Some Nokia phones will fail to work at all when specified IMAP over SSL.
All phones will work if we allow non-SSL encrypted IMAP traffic.
It really seems to be hit or miss, I've gone through updating phone software on those that don't work but that's not made a difference.
Unfortunately, a lot of people rely on e-mail access over their phones (field engineers) and I'd rather not allow non-encrypted IMAP traffic due to compliance requirements.
Other than assuming that some phones are just quite sensitive in this area, is there anything else I can check out/configure that might alleviate this issue?
Thanks,
David
I'm guessing the Nokias that don't work don't have Comodo's Root CAs in their Trusted Root CA list. You should be able to import it (it's available to download from their website), but not sure how hard that is.
I've had this before - Comodo are using a new root CA which not all phones have.
If you log a support ticket with COmodo via http://support.comodo.com/ and ask for them to "Reissue your certificate on legacy for mobile support"
They will free of charge issue you a new certificate signed with a different root CA. You'll need to provide them with either your domain name OR order number, and also a new CSR request (so you'll need to go through the whole certificate registration again on your server unfortunately).
It should sort you out though.
Every time i've done this, Comodo have reissued my certificate signed with the "AAA Certificate Services" root CA.
Comodo's mobile support isnt the best, along with their quality of vettig applications. For the best mobile browser compatibility I would recommend Verisign or GlobalSign SSL. 99.9% compatibility, due to them producing certificates for the longest period, the root of their certificate is in all the browsers/mobile devices/consoles etc.
