- 6 Sep 2008
- Near Hull
When i got my bike (ZX6r F3) it had a micron end can on it and i was also supplied with a remus end can for MOT purposes. The end cans are just slip/bolt on cans and i had no problem changing to the remus can, all went on nice and easy.
This morning I've changed it back to the Micron can and i've tightend up the 3 bolts, but it's blowing a bit from near the bottom bolt. like when fitting the remus all i have done again is removed one and fitted the other.
Should i be changing/adding a gasket or is their something else i can do?
