exporting contacts from iPhone to Android
14 Dec 2005
just got a Vodaphone Smart Ultra
all my contacts are saved on my old iPhone4s - there is no way to get the contacts on to the sim card from the iPhone??
I googled this and downloaded an app called Contacts Kit, but when i try to use the vCard file created on the new Android phone I get a message saying the format isn't supported
do i just have to do it manually?
brilliant, thanks for that
I had emailed the vcard file to myself then opened it on the Android phone but it still didn't work - said format not supported
the way you describe worked fine tho - thanks again :)
No problem, make sure to save any new contacts directly to your Google account as well, that way when you upgrade again it will be just as easy as signing in to your Google account. Even iPhones can sync with Google Contacts ;).
Just create a Google Account on your iPhone, sync contacts then use that same Google account on your Android phone.
Job done.
