Hello all...
I am a Mac user and I am looking for some advice regarding backup.
The backup should be used for the following:
iTunes library
Aperture or perhaps iPhoto as I might go back to that (don't ask).
Various instruction movies
Regular documents and invoices.
A lot of my illustrations
client sites (or even a local server)
Huge amount of creative resources - fonts, sounds, brushes, stock images etc..
Right now I have the following hardware:
iMac - 500gb
TimeCapsule - 500gb
2 Old 320gb MyBooks running FW400 (but they behave a bit odd from time to time - not always showing up in Finder).
1 old Maxtor 1Touch 300gb - USB 2 working fine but slow and a bit loud.
A lot of spare SATA drives 500gb - 200gb.
I have the following options:
Upgrade the TimeCapsule to a 1.5tb drive if possible
Drobo and use some of the biggest spare drives I got (still I hate the price).
A Synergy box perhaps?
I also got some spare parts so I could make a computer running as a fileserver - rather cheap option. (Still I would hate to have such a box running 24/7 - and not shure how well it would work with various harddrives and how easy it would be to get it to be a good backup solution).
A couple of big FW800 MYBooks running mirrored mode (relatively cheap for the 1TB version).
I also got a PS3 and it would not be bad if it could talk with my solution, but not really a must have. I just want a good backup solution...
Would you mind sharing your thoughts - what works, have you tried some of the same solutions etc..
The Drobo does indeed look like a lovely solution, but I just hate the price....
Thanks in advance!
iTunes library
iMac - 500gb
TimeCapsule - 500gb
Thanks in advance!
