External/Desktop Temperature display ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Hi all.
I'm after an external display for temp monitoring ( I can't see what the system temps are when running games ). I was using a 20x4 lcd screen connected via parallel port and mounted in a frame that sat on my desktop.
New mobo has no parallel port.
Ideally USB connection , that displays CPU and GPU temps , that can sit on my desk near the screen.
I don't seem to be able to find anything similar , Any ideas ?
Thanks,
Mark
Alphacool LCD-Display 240x128 Pixel Blue about 70 quid from atleast 3 other retailers.
linky
works in same way as matrix orbital etc does with plugins for things like speedfan (which should cover all your main needs :))
Another idea would be a Logitech g15 keyboard, its got a display on it, and with the right software will show you everything :)
Naud
