I've always been told that if I wanted an external hard drive, the best thing to do would be to buy a normal hard drive and stick it in an enclosure, then you could plug it into whatever PC you ge later on.
However, I'm now looking for extra portable storage that I can easily swap between my laptop and PC, so I can watch various anime I've downloaded on my PC drives, just on my laptop when I'm away, as the 40Gb hard drive isn't really enough now.
This offer certainly has my interest, since it seems to be cheaper than all the SATA 400Gb hard drives you do, plus there would be an extra cost for buying an enclosure.
But I don't know much about USB external hard drives. Are they any less reliable than normal ones you put in your PC? Also, when they say 400Gb, its going to be about 370 isn't it because of the rounding thing they always do. Finally, what are the speeds like compared to an internal drive? I know you shouldn't run newer games from them since you're limited by the speed of the usb ports, but other than that, they are just as good as the internal ones, right?
Finally, when does the offer end on the drive?
