External HDD not showing under explorer?
16 Aug 2005
Hi guys, I have come across an issue with my external drive where its not being found under explorer but shows under disk management as unallocated?
Is this easily fixed or shall I return it to Western Digital :(
Thanks in advance, Onam.
It gets picked up in device manager, and under add or remove devices but doesn't give me the option to format. Theres a black line when I view it under Disk Management stating its unallocated...
I am trying a new partition on the drive but it doesn't allow me to format it as a FAT32? Ideally, I want it this way so it cannot to my TV and PS3...
It might not be allowing you to format FAT32 because there is a 32GB limitation in windows for formatting FAT partitions.
This Post should sort you out.
