External HDD not spinning - PANIC!
Consigliere
12 Jun 2004
SW17
:eek:
Okay, i haven't used it for a few months..WD 250Gb i think, an iBook or something like that. Just tried to power it up and nothing is happening...just a faint buzzing noise.
Any ideas? :(
not familiar with them myself, but when my external drive refuses to spin up its usually a power issue. Is this one USB powered, AC powered or both ?
One of my external enclosures actually has two power inlets, both driven by usb, (data only flows over one of the two, the other is power only - just to power hungrier 2.5 inch drives.)
don't worry just rma it and restore your backup to the new drive :0
if it's an external enclosure thing, then remove the hard drive from it and plug it in internally (or into an icy box)
I had a similar issue with an old IBM 120GB drive, I tried doing stuff like switching the controller boards to get it working, but like with yours there was just a (faint) buzzing sound when it should be spinning up. Eventually i just gave the drive a hard knock on my computer desk and it came to life. I guess the motor might have just seized due to lack of use.
this happened to me with a hard drive in work, the only thing i needed from it was a bat file for making backups (which i'd spent a few hours perfecting) -ironically i'd not backed up the bat file
after failing to get the drive to even post, i was real annoyed, and kicked it across the room, it smashed into a metal filing cabinet.. I plugged it back in and voila it's been working fine since (no errors in smart -not that i really trust smart, but still)
