External HDD Problems
Permabanned
7 Oct 2006
Hi,
I have a 320gb Seagate external HDD and it is giving me grief, you lot are a bright bunch on here so someone might know how to resolve ths problem:
It has 200gb free and I am trying to copy a 32gb file over to it. It just keeps saying that the drive is full! I am totally stumped! It should fit easily!
The drive I am copying it from (an internal HDD on a laptop) only has 22gb free, could this be the problem? does it have to do some odd duplicate of the file as it sends it accross or something?
Any help or suggestions would be much appreciated.
I'm going to guess that the external drive is formatted as FAT32 in which case it has a 4Gb file limit and would return the error noted if you try to exceed that.
Jimmy_Lemon said:
Poop! yeah its fat32 - its all coming back to me now! Thanks for your help :)
You can do a one time conversion from fat32 to ntfs using the convert.exe utility which comes with Windows
