hello!
I'm thinking of buying a large external Hard drive (around 250gb) which I'm basically going to use for extra storage but mainly as a backup of my current HDDs. I was wondering if someone could answer a few questions for me please:
1. is it better to get an external drive or buy an internal drive and put it in an enclosure?
2. can I attach an external HDD using a SATA cable? I'm planning on also buying this Akasa control panel (the one at the top) which has SATA data I/O so would probably hook it up to that. would that be possible?
3. if i want to back up my current HDD setup (i have about 150gb worth of stuff) would i need to use norton ghost or something or can I just select everything and copy it over?
4. based on Q1., can anyone recommend a manufacturer? I've got 2 seagate barracuda's and while I find them reliable, they are a touch noisy. I'm thinking of going with samsung but haven't decided.
Thanks.
Thanks.
i put in the sata pci plate that came with the icy box to get my drive detected. im a bit upset as the front sata port was one of the reasons i wanted the akasa.
