do you need to install a driver to get it working in windows or do you just plug it in ans away you goBONES__69 said:Well logic says get a Seagate Hd as these are the only 7.2k Hd's where the entire range are backed by a 5 year warranty.
I just bought a Seagate 250Gb HD and Icey Box which works really well (Have the option for both USB2 + Firewire). It is both quite and fast with the added benifit of looking kool
bbreezeuk said:do you need to install a driver to get it working in windows or do you just plug it in ans away you go
