Does anyone use internal hard drives in an external enclosure but connected using direct SATA connections instead of USB connections? Presumably this is as fast as a normal direct connection to motherboard?
Can anyone recommend an interface card for this, and/or advice? The aim would be to minimise the amount of kit inside the case to maximise clear space.
Thanks
Thanks
, psu was just too noisy.
