External possibly over-heating
2 May 2004
Hi,
Over these couple of hot days (33 c+) my external has been ftdisking and disconnecting itself and re-connecting all the time.
Each time it has started doing this I have felt the external and it seems a bit too hot.
The drive never ftdisks in the winter or on cooler days (today it hasn't done it once and it's been cool).
Anyway, I just wondered if it's safe to carefully open it up and clean it out. I've had it for about 2 years now and haven't cleaned it out so it might be overheating because of the hot days & dust.
Thanks,
Craig.
I could do, but really need a no-money solution as I really don't have any money at all at the moment :(
I could get a £1 sport relief fan :p :D
If I opened it up wouldn't it be like opening an internal hard drive and i'd see all the shiny CD thingys inside? Or would they all still be covered when I take the casing off?
Thanks,
Craig.
Sparky191 said:
They are not designed to be used as much as regular drives. IMO. I've had problems with newer hotter drives in them.
Hmm, maybe it's being used a bit too much? I've got 'My Documents' on there instead of my C: driver, maybe that's making it over-work itself? I'll see about moving My Documents to my C: drive instead (it's on my external because I used to have a 40GB hard drive so it saved a lot of space sticking my documents on my external 200gb instead of on my main drive, but now i have an internal 200gb so I'll move it back some time).
Thanks,
Craig.
Seems to be fixed now. I've put My Documents back on my C: drive and the external is now almost cold to the touch & hasn't ftdisked since.
Must have been due to just about continuous use: Music, pictures, saving stuff to my documents, reading stuff from my documents all the time etc.
Thanks,
Craig.
