External SATA enclosure / rack for multiple HDD's
18 Oct 2002
At home
Hi,
My file server case is literally running out of space. I was just going to pile up a couple more HDD's outside the case and dragging the SATA cables through a spare empty PCI slot.
Just wondering if there is a tider solution around ? Almost like a HDD shelf ?
Thanks,
There are various options available to you.
1) Something like an IcyDock MB-561S-4S, basically 4 external HDDs in one box, with 4 eSATA connections. You can then either run long SATA-eSATA cables or use some eSATA backplate converters to give you eSATA ports. There are similar units about that only have a single eSATA connection with an internal port multiplier but your potentially limited by the speed of that link although for a file server you'd probably be OK.
2) An internal solution like a Lian Li EX-34 which will give you 4 3.5" bays in 3 5.25" bays.
