- 17 Jan 2006
After a lot of thought, as detailed in this thread: http://forums.overclockers.co.uk/showthread.php?t=17564388, I have just purchased an IDE hard drive and an Icy Box enclosure.
The drive is a Western Digital 320gb, and the Icy Box is the USB 2.0 one.
I've put the drive in the case, and connected it up to my computer. It was recognised by windows, and after initialising it and formatting it to NTFS, I could see it in explorer etc.
I thought I'd do a few tests to see how quick it was for copying files as this will be used for my backups. In explorer it seemed reasonably fast, so I thought I'd go ahead and give my backup software a try (SyncBack SE).
The first thing I did was to get it back up some small files, for which it was fine. Then I got it back up my Photo folders, they contained about 5,600 files and were about 11.8gig in total. It started off fine but then when it got to a quicktime panorama which was about 108mb it ground to a halt, by that I mean, it stopped flashing and the file size remaining info in the software stopped going down. I also received a windows delayed write failed error message.
I thought thatmaybe it was because it was a largish file that it might have caused a problem, so I tried stopping the back up, which I could not do as the software had frozen. I launched Task Manager and got it to close the software. I then opened Explorer and tried to see how much had copied to the external drive, but the computer could not access it.
I tried using the safely remove software options but it just said that it could not be stopped at that time. In the end I had to turn it off at the power switch.
I restarted the computer and switch the external drive back on,windows again recognised it. I decided to try to copy a large file across to see if that was the problem, I tried in windows explorer and it was fine, an infact faster that I had thought it would be.
I then tried in SyncBack and it worked fine, so the file size couldn't have been the thing that caused a problem.
I tried doing another backup and again it started fine but after a short time, it ground to a halt againg, this time on a 1.4mb bmp file, again i got adelayed write failure message and could not access the drive at all.
I have looked at the setting for te drive and wondered if it might be becauseit was set to "optimised for hot swapping" or whatever the option is called I changed that to "optimised for performance" and tried again but te same thing happened, it gounrd to a halt.
Can anyone think of any settings that might cause this behaviour that I can try to change before I have to try to return the hard ware as not suitable, because, I can't run backups onto this drive with it malfunctioning in this way!!!
Thanks in advance for any help anyone can give me
(sorry for the essay!!)
Valve
Valve
