Hello
I've a house that's around 100 years old. Solid walls - no cavity walls here. It get super cold in the winter, and the walls seem to radiate cold. So we're thinking about external wall insulation.
We'll fit it over pebbledash (it seems that you can do this without removing the pebbledash) - and use brick slips where we have brick to keep the character of the place. We're also planning an extension sometime in the next couple of years, so we're not sure if we'll wait for that to happen first and then render everything together.
Cost is a concern. But I hear there are grants? Also humidity/ ventilation is a worry.
Have any of you done external wall insulation? How did it go? What do you wish you'd known at the outset?
