Id save the 3.8ghz profile in bios incase you want to do a few bench runs, then run the system @3.6ghz for daily use, your unlikely to hit the sort of temps you get in p95 load in everyday tasks.My q9550 @ 3.8ghz 1.3vcore(bios) 1.23(windows) max temsp 72-70-68-69 during prime
or
stock volts 3.6ghz and max temps 60-57-56-68
is the extra 200mhz worth the extra volts and heat??
artic cooler
