- 7 Jul 2008
- Newcastle upon Tyne
I currently have Virgin Media wires and wireless in the house plus some TP Link homeplugs. My house is a 1930 semi so fairly decent walls
The problem I have is the wireless range is not brilliant. The wireless router is in the bedroom which is an office however the signal is poor once I get to the kitchen and fairly nonexistent when I go into the attached garage.
I do have a TP Link range extender but to be honest it does not help.
So what I would like to do, if its available, is get a homeplug wireless access point. That way I should have the same coverage downstairs as I do upstairs. I assume I will end up with two SSIDs ie upstairs and downstairs.
Can anyone recommend a warless access point homeplug (not range extender) that will work with my existing TPLink homeplugs?
Any other advice would be good, ie you may have an alternative solution that I have not thought of
