24 Nov 2007 at 13:47 #1 chipperhead chipperhead Soldato Joined 7 Feb 2004 Posts 3,073 I'm after extracting a few seconds of audio from a 2 hour long .avi file, can someone recommend a program to do this. Thanks.
24 Nov 2007 at 14:24 #2 rpstewart rpstewart Man of Honour Joined 11 Mar 2003 Posts 10,704 Location Greenock, Scotland VirtualDub will do it, it's not the easiest program to pick up but it works well. Load the AVI, trim it to the required length then File...Save As WAV.
24 Nov 2007 at 15:04 #3 chipperhead chipperhead Soldato OP Joined 7 Feb 2004 Posts 3,073 rpstewart said: VirtualDub will do it, it's not the easiest program to pick up but it works well. Load the AVI, trim it to the required length then File...Save As WAV. Click to expand... Thanks, used VirtualDub like you said, worked a treat
