So that last of the watercooling gear have arrived
As I said, I do no believe that radiator cooling will be my bottleneck, and here's why:
http://www.overclock.net/content/type/61/id/1871804/width/500/height/1000
One big, fat 9x120mm radiator (60mm thick)
http://www.overclock.net/content/type/61/id/1871858/width/500/height/1000
And when you place that in a Phobya radiator stand along 18 Antec fans it looks like this:
http://www.overclock.net/content/type/61/id/1871844/width/500/height/1000
http://www.overclock.net/content/type/61/id/1871845/width/500/height/1000
That is a heavy setup, and there is one more of those along the white/green radiator (45mm) posted above
And they cool really well.
Right now the green/white radiator + D5 pump is cooling a mining rig with a HD 7990 + 2x HD 7970 down to the cores are at only 44 degrees and water around 37 degrees (and that is a 24/7 setup)
And that is with only four 180mm fans at 700 rpm.
So the three of these radiators with push pull configuration with the 2000 rpm should be more than enough for this chiller
I also got some extra stuff, like an extra D5 pump to help in the cold loop and four temperature sensors (green LCD of course) and a lot of screws for the fans:
http://www.overclock.net/content/type/61/id/1871848/width/500/height/1000
** No hotlinked images **
Some of the Monsoon fittings also arrived, and quite a lot of them;
http://www.overclock.net/content/type/61/id/1871849/width/500/height/1000
And when taken out and assembled it looks like this;
http://www.overclock.net/content/type/61/id/1871850/width/500/height/1000
Beautiful
But this is not all of them, actually these are just around half of what I need for this chiller and SG09 build (around 30 pcs. both fittings and angle adaptors).
Some of the are in the mining rig, others are not yet bought due to uncertainties of how many TEC waterblocks that will be made (how many fittings is needed).
And once again, thanks to Monsoon for sponsoring some of their fine fittings, and I must say you are right;
http://www.overclock.net/content/type/61/id/1871851/width/500/height/1000
"Bling is good"
As for the TEC waterblocks I will go with the long thin lines, but have had time yet to design/draw them.
But should happen soon and hopefully I will find some cheap (but good) copper at that time.
(if you got a link to a seller in EU (that ships to Denmark) please post it
I don't have that much more, except that I got a new pump for the SG09 (other one burst into flames) and I swapped out the GTX 670 4gb cards for a new;
http://www.overclock.net/content/type/61/id/1871853/width/500/height/1000
A nice Gigabyte GTX 780 TI
http://www.overclock.net/content/type/61/id/1871854/width/500/height/1000
It came as rev 1.0, so thought It was the reference PCB design, but luckily it was the custom more powerfull design
http://www.overclock.net/content/type/61/id/1871855/width/500/height/1000
http://www.overclock.net/content/type/61/id/1871856/width/500/height/1000
I tried the card, and I must say it performs well and is really silent. Even in game after many hours of play, I cant hear it even with the case open (bot only at stock clocks for now and 1.5 meters away from case).
So that will be the card that will get chilled
(maybe another one will come along as well if my wallet is up for it).
And EKWB is making a full cover waterblock for it (yea), bot it will first get released in late February :-/
But when under the chiller it will be with a core block only (either custom one or a EKWB block), and with heatsinks on Vram and VRM.
So that's it for this time, any questions is welcome, and link to a good but cheap copper retailer is appreciated
