- 29 Dec 2012
hi all, I have recently rebuilt my water cooling loop and added an extra radiator and my gpu; since doing that the noise from the pump has been pretty terrible at anything but the absolute minimum speed before it stalls. It is mounted to the bottom of my case on top of the ek rubber standoff thingies http://www.overclockers.co.uk/showproduct.php?prodid=WC-505-EK
My loop is:
EK DDC xres 140 with the multiport top
an ek full cover 290x block
xspc raystorm cpu block
alphacool nexxxos monsta 240mm radiator
an xspc 30mm 240 radiator
I'm fairly sure the 18w ddc should be able to handle this loop without much fuss but if i'm wrong fair enough.
what are my options for silencing this thing? needs to be a rigid but decoupled mount since the reservoir and pump are in one unit. I did consider switching to a d5 xres and may well still do that if i cant silence this ddc.
I am rebuilding the loop again soon anyway as i am not happy with how my first time bending acrylic tube has turned out which I expected.
any advice appreciated
thanks,
smithy
My loop is:
thanks,
smithy
