Hi all
Recently made an order for 3 x Samsung S27B750HS 27" Widescreen LED Monitor.
My problem is that I went for aesthetics and never bothered to check the input connections (1 x HDMI and 1 x D-Sub) so I'm unsure if I can run these in Eyefinity for gaming.
The system Has 2 x HD7970's but from what I've read I should only connect the Monitors to the primary Graphics Card which has 1 x DVI, 2 x mDp, 1 x HDMI.
Now would it work if I was to connect the HDMI to HDMI (obviously) then adapters for the mDp's to HDMI.
I'm a noob with a passion for having all the gear and no idea but plan on learning as I go, just need an answer before the order is dispatched so I can make a change if necessary.
Cheers
G
Cheers
G
