Ohayo!
In few upcoming days I'll be ordering all the remaining parts for my new system, and I rather double check that I am making the right choices.
First of all I'm listing few things I already own:
And this is what I will be probably getting:
Total for everything is about £2600. Now, my concern is if I should take i5 2500k instead of 3930k and get another HD7970 for EF gaming, or just leave it as it is(2xHD7970 + 3930K) and wait for HD7990.
The bad thing about Z68 setup is that I can fit only 2 GPU and the soundcard on the mobo. Which means if I would like to add another GPU in the future I won't be able to do that because of it, so I will have to either remove the soundcard or just stick with 2 GPU.
Any advices?
- 3 x Dell U2312HM
- Creative Titanium HD
- AKG K242HD
- Razer Mamba
- Razer Vespula
- Logitech X-540
- Samsung F3 1TB
- +Other crap...
- Intel i7 3930K - Now you might ask if I do any heavy stuff, the answer is no. I do have dSLR camera, and I will play with Photoshop or some video editing, but for that 2600K would be way enough. So the reason I'm looking at 3930K is 6-cores, more futureproof, and I will run heavy GPU on it.
- Asus Rampage IV Extreme - Design, and PCI spacing. I will be able to fit in 3 GPU with my soundcard. So when HD7990 comes out, it will be QuadCF.
- Corsair Dominator 1866Mhz 16GB - Yeah, overkill, but it's X79!
- Corsair H100
- Corsair 800D - So many people have it... I want to be unique... good case tho.
- Corsair 1200AX - Well, X79; 2 GPU. In future QuadCF, Water Coolig.
- Crucial M4 128GB
- Sapphire HD7970 x2 - Good for eyefinity, from what I've seen and heard.
- Logitech G510 - Can you access BIOS with this keyboard? I've seen people having problems with it.
- Samsung DVD Blu-Ray
Any advices?
