Eyefinity Stuck on Low Res
30 May 2008
Sheffield, England
I've tried every other options so I'm hoping that one of you knows of a solution to this issue.
I've had an eyefinity setup for just under a year now, running across three identical screens at a resolution of 5760x1080 without issue.
Today I removed all the cables from the rear of the PC to give it all a good clean and since I have reconnected everything and restarted the computer I am only being offered a resolution of 2400x600.
I have tried reconnecting the cables, rebooting, reinstalling and updating drivers to no avail (10.5 originally, 11.2 installed now).
I have double checked the cables and they are all in the original ports, so absolutely nothing has changed except for the resolution now being stuck on 2400x600.
Anyone have any ideas?
Thanks in advance.
edit: forgot to add, I can run the monitors in 'single' format, with the desktop extended across all three at a resolution of 1920x1080 per monitor, however I am limited to just 2400x600 under grouped resolutions.
Never mind, did a system restore to earlier this morning and everything has gone back to normal.
I really don't understand computers sometimes.
