F.E.A.R. Extraction Point Problem
28 Oct 2004
Somewhere, in a field in cheshire... alright!
Hello
I'm having trouble getting F.E.A.R.XP to run. Keep getting a box that says "Warning! Your system time appears to be incorrect, would you like to verify it against the Securom Timeserver" and "Invalid system-time detected. Please check and correct your local system time setting"
Dont understand why its suddenly saying this as I have played the game upto Interval 5 without problem.
Anyone have any ideas whats wrong?
Thanks
Have you checked your PC's Date / Time settings , and did you download it via D2D?
I did uninstall and reinstall but no change. Then i tried changing the date from may to june and it worked so problem solved at the moment. Thanks though.
