F@H problem
Don
5 Oct 2005
Liverpool
Hi All,
I'm getting the following errors...
Error: Got status code 407 from server
Could not connect to Primary Assignment Server for ID
Really wanna help out with F@H any ideas??
Stelly
Stelly said:
Hi All,
Stelly
firewall?
proxy server?
I think we block every port apart from port 80... I have tried using both windows explorer and toher settings for proxy but does not work
Stelly
Does your fahlog.txt have listed the IP address(es) of the server(s) it's trying to contact? If so, try entering the address into your web browser and seeing if it will let you go there. If you do not have address listed, check to be sure you're running with -vebosity 9.
Launch directory: C:\folding@home
Executable: C:\folding@home\FAH504-Console.exe
Arguments: -verbosity 9
[15:09:50] - Ask before connecting: No
[15:09:50] - Use IE connection settings: Yes
[15:09:50] - User name: stelly (Team 10)
[15:09:50] - User ID not found locally
[15:09:50] + Requesting User ID from server
[15:09:50] - Getting ID from AS:
[15:09:50] Error: Got status code 407 from server
[15:09:50] + Could not connect to Primary Assignment Server for ID
[15:09:57] ***** Got a SIGTERM signal (2)
[15:09:57] Killing all core threads
Folding@Home Client Shutdown.
Thats what I'm getting...
Stelly
I'm screwed lads, not getting past the proxy.
I have a lappy at home... it has the following spec..
Intel Centrino Core Duo Processor 2.0GHz
2GB DDR2 SDRAM
120GB Hard Drive
DVD Dual Layer Drive - To read DVDs and CDs and write CDs, DVD+, DVD- and large Dual Layer DVD
15.4" WSXGA+ Widescreen TFT Screen
ATI Mobility Radeon X1600 PCI-E 512MB HyperMemory graphics (256MB dedicated)
Integrated gigabit LAN and 56k v.90 data fax modem
Would that be ok to help out?? :)
Stelly
BillytheImpaler said:
As above with all machines, except the laptop (1.6GHz Centrino) as it tends to get a little hot - especially if I've been blasting aliens :o
I switch it o** for about 1 night per week :(
Stan :)
