yes it does - it automatically starts 4 instances but should still work fine on only two coresVeNT said:does the SMP work on dual core too?
I'd be interested on the core duo results.
KE1HA said:Anyone have any data on how the SMP's (Quads) perform on 64-Bit Linux in SMP mode ?
I have a testing rig that I may change over to a quad quad core & install Linux 64 v.s. WinDoze if the performance is better.
Opps, bit of a type-o in my original postDreederOcUK said:That must be some kind of kickass server motherboard to allow 4x Quad core chips, im moist with anticipation of the Dual Quad Core Macpro, but Quad Quad Core must be amazing.
. It's not a Quad or MP processor board, it's a board capable of running the Quard Core Single Intel Processor = QX6700 Kentsfield Processor. Most of the newer Core 2 Motherboards can run them.That's really a mute pointHowever, Youd need to run 4 copies of the SMP code to make full use of all 16 cores... each SMP client uses 4 cores.
as I dont have a 4 Processor capable Motherboard, wish I did !!!
