F Panel problems
16 Jul 2006
Birmingham/oxford
Building my comp for first time, im having problems with a couple of cables,
I cant find where the cable labelled POWER SW goes, also the F-panel leads, the RESET SW AND HDD LED I know where they go but dont know which way round so the are the right polarity.
If a cable had a black and white wire which is positive and which is positive out of black and red?
Sorry about this but I havent been able to find the answer in any of the manuals
help would be much appreciated
The motherboard manual will tell you exactly what goes where. There may also be markings on the board itself. Polarity with switches (power and reset) doesn't matter, they will work either way round. For the leds, usually white would be negative, but if you're unsure try it one way and reverse it if the led does not light up.
