but can the driving controls (forward, revece, left, right) be configed to the right analog stick ?yes i'm using an xbox controller
I couldn't find a way to re-configure any of the buttons on my 360 pad - wanted to change the gear up/down buttons to be the same config as Forza 3.
Might be able to change settings in some .ini file somewhere though? Haven't looked. Check the Codemasters forums.
the manuel says this:I couldn't find a way to re-configure any of the buttons on my 360 pad - wanted to change the gear up/down buttons to be the same config as Forza 3.
You can customize the controls exactly how you like them in the Options menu, or just use the
defaults shown here:
anyone???can someone with a xbox360 controller try to config the driving controls (forward, revece, left, right) to the right analog stick, and please let me know if it works..
hi
before i order this game, i would like to know are the controls fully configurable? because i like the driving controls (forward, revece, left, right) on the right analog stick .
anyone???
Just to ask, you have all the driving controls on 1 analog stick? Thats crazy, completely, it means you cant go round corners on full throttle?
yes you can as i have allready said, but i would use right as throttle/brake and left as turning left/right?
yes im disabled, i can't use my hands. so i use my chin,Maybe he's disabled, only has one hand, or something like that?
yes im disabled, i can't use my hands. so i use my chin,![]()
that wouldn't be any good for me that way.but i would use right as throttle/brake and left as turning left/right?
