F1 or F2EG?
3 Jun 2007
The Samsung F1 here: http://www.overclockers.co.uk/showproduct.php?prodid=HD-053-SA&groupid=701&catid=14&subcat=1279
And the Samsung F2EG here: http://www.overclockers.co.uk/showproduct.php?prodid=HD-076-SA&groupid=701&catid=14&subcat=1279
Have identical seek times, cache, etc. But the F2 has a speed of 5,400RPM whereas the F1 is 7,200RPM.
I program a lot and game, I'm just wondering which one would be better?
FYI: At the moment I have two Samsung 500GB drives (both about 24/18 months old, still working fine!), would I achieve any performance gains by getting one drive instead of 2?
The F1 is faster if you're using it as a system drive. The F2 is quieter and lower power, ideal for a storage drive.
Hmmm... how did you figure that out? Personal experiance? I'm just wondering how one can be faster than the other when seek times are exactly the same.
The 7200 RPM drive is slighty faster in transfer rate and latency. But uses more power and isn't as quiet as the 5400rpm drive, although I've been told the F1 is pretty quiet so I doubt there's much difference in acoustics there.
F1
Code:
Drive Configurations   Capacity *  	 1 TB
Interface 	Serial ATA 3.0 Gbps
Buffer DRAM Size 	32 MB
Byte per Sector 	512 bytes
Rotational Speed 	7200 RPM
Performance Specifications Average Seek time(typical) 	8.9 ms
Average Latency 	4.17 ms
Data Transfer Rate / Media to/from Buffer(Max.) 	175 MB/sec
Data Transfer Rate / Buffer to/from Host(Max.) 	300 MB/sec
Start/Stop Cycles 	50,000
Acoustics Idle 	2.70 Bel
Performance Seek 	2.90 Bel
Power Performance
Spin-up Current (Max.) 	2.4 A
Seek (typical) 	7.6 W
Read/Write (typical) 	8.4 W
Idle (typical) 	6.7 W
Standby (typical) 	0.7/1W
Sleep (typical) 	0.7/1W
F2EG (EG stands for EcoGreen)
Code:
Interface 	Serial ATA 3.0Gbps
Rotational Speed  	5400 RPM
Average Latency 	5.52 ms
Data Transfer Rate / Media to/from Buffer(Max.) 	166 MB/sec
Drive Ready Time(typical) 	12 sec
Acoustics Idle 	2.50 Bel
Performance Seek 	2.80 Bel
Power Performance
Spin-up Current (Max.) 	2.0A
Seek (typical) 	5.2W
Read/Write (typical) 	5.6W
Idle (typical) 	4.4W
Standby (typical) 	1W
Sleep (typical) 	1W
If you are looking for performance gains, why not Raid the two Samsung 500Gb drives? And get a F2 for storage. Unless you are already.
Spot on.
The faster rotational speed increases performance, regardless of the seek times.
